- Joined
- 5 Apr 2017
- Messages
- 8
- Reaction score
- 0
- Country
I've pulled it apart and it says 13/20 amp 250v. I can't seem to find anything on screwfix that says it's 20a with a fuse. They are all plain switches only from what I can see. The only fused ones are marked as 13a.
Swapping this should be plug and play once I find the right part, my problem was fault finding as I've not encountered problems before. The input wires go into the feed, and the output to the element go into the load in the correct L/N terminals which I'm happy to do. Everyone else have all been happy to offer helpful advice and don't seem to be bothered about me having a poke around.Your Immersion uses a double pole switch for a reason, when it is switched off it cuts the Live and the neutral supplies, do no mess around with it get someone that knows what they are doing
