I have also seen all three in various places burnt out.
Would that be due to you're wiring method? i.e. 32a OPD protecting the wiring
Regards,
DS
The rating of the OPD is surely irrelevant? An accessory will only 'burn out' if an excessive current flows through it (or if the termination of conductors within it are not satisfactory) - and, to-all-intents-and-purposes, an immersion cannot create such an 'overload', no matter what OPD is protecting the circuit.Would that be due to you're wiring method? i.e. 32a OPD protecting the wiringI have also seen all three in various places burnt out.
The vast majority of domestic immersion heaters are 3 kW, aren't they? Although that is theoretically still within the rating of a 13A plug - but, as EFLI has said, that can result in problems.How many kilowatts is the immersion heater ? If it is 2 kW that it can be on a 13 amp plug. ( good quality one, not a 99p one ).
... or (as EFLI has also said), preferably, a two-pole (probably "20 A") switch.Having it on a plug or two pole FCU allows it to be fully isolated when it develops an earth leakage fault.
I didn't say that 2 kW one's don't exist but, rather, that the vast majority of domestic ones are 3 kW, and I still think that's true.here we go ...
WTF ?The rating of the OPD is surely irrelevant? An accessory will only 'burn out' if an excessive current flows through it
What's your difficulty with what I wrote - it's surely a statement of the obvious, isn't it? If the nature of the load is such that it cannot result in an ('overload') current greater than, say, 13A, then an accessory which can tolerate 13A without 'burning out' will not burn out, whether the OPD is 13A, 20A, 32A or 50A.WTF ?The rating of the OPD is surely irrelevant? An accessory will only 'burn out' if an excessive current flows through it
