I installed an immersion heater 8 months ago (as a plumber I have fitted a considerable number) then all of a sudden the thing stops working. there is a reset button which clears the problem on the top but as it is so fiddly it is no real solution. I have tried swapping the thermostat (long thin one) but this also went off after two days. I suspect it is an electrical supply problem tripping it out but am at a loss to the answer (the supply is ok by the way on when it should be and off when not 230v ish)
