Anyone know of a wholesaler where I can buy a 1 1/4 imperial conduit 2 way through box? Am only after 1 - maybe someone has one kicking about somewhere?
I have got my hands on a few 32mm locknuts and bits, I can tell by trying to screw a 32mm short male bush into a 1 1/4 coupling that it is tight, but with a little bit of oil it will go!
For now I will go with using a steel adaptable box with a couple of 32mm holes drilled in it, I intend to use a couple of locknuts on each conduit thread - one inside and one outside the box.
