T&E in conduit, grouping, derating questions
Sorry, :cry:
I didn't for a second think anybody with be stupid enough to think they would all go down one 25mm tube !!!!!
silly me,
Lxboy
Roughly Area inside conduit is 490mm². (not sure of internal measurements)
45% of 490mm² = 220mm² which is maximum allowed.
I'd suggest that the normal rules for conduit fill don't really apply here. T&E in white oval is a bit of a special case IMO.
I'd also suggest that the normal rules for conduit fill don't really apply when using T&E in round conduit. Unless you are really careful, then the odd shape of the T&E makes the space it takes in the conduit somewhat more than a simple consideration of it's actual size suggests. Ie, if there are any twists (almost guaranteed without a lot of care), then the effective size is more like a round cable with a diameter equal to the larger dimension of the oval cable. So your fill factor would have to be lower when using T&E (or any other flat/oval cable).
I'd suggest that the normal rules for conduit fill don't really apply here. T&E in white oval is a bit of a special case IMO. I'd also suggest that the normal rules for conduit fill don't really apply when using T&E in round conduit. Unless you are really careful, then the odd shape of the T&E makes the space it takes in the conduit somewhat more than a simple consideration of it's actual size suggests.
Indeed so. As I wrote in the footnote of my table of approximate overall CSAs of T&E:
However, guidelines in relation to CSA's is obvioulsy only part of the story when deciding what cables will even fit in what conduit (particularly if oval)!
Kind Regards, John
