My last daft question for a while…
After reading this forum for a while with regard to the wiring I’m going to need in my kitchen I’m now considering having my CU replaced as part of the same job.
It’s currently an eighties vintage Crabtree unit with big brown breakers. The existing circuits are cooker (30A), ring (30A), upstairs lights (5A), downstairs lights (5A), immersion (15A) and one spare. There’s also a small much more modern CU alongside containing a 40A MCB and a 63A 30mA RCD that supplies the shower. There’s a sticker on the main CU stating that it’s connected to a Protective Multiple Earth system.
The CU is basically pig ugly and is located in my hallway with no good way of hiding it. It also doesn’t appear to have any provision for adding RCD protection to any of the circuits which I’d prefer. Finally at some point I’d like to get mains out to my shed and have something more substantial than the existing single socket spur in the attached garage.
Is it likely that the CU can simply be replaced, or is there going to be a lot of other remedial work required? I know that without actually inspecting the wiring a simple yes or no answer won’t be possible but I’d appreciate any insight into the likely problems.
Due to a lack of planning on my part (and knowledge about part p) everything is on stop until I can get an electrician on site. I need something to do in the meantime even if it's just looking for potential problems.
Thanks.
Thanks.
