No, and I wouldnt. And I'm just a keen DIYer. Anything "Made in China" cant be as good as that made in France, Germany or UK, expecially when its half the price.Thats real quality stuff mate.![]()
Have you used it?
Have you used it?
I think I've read that Wylex are good but apparently not the cheapest.Thats real quality stuff mate.try this consumer unit for size
http://cpc.farnell.com/pro-elec/acu10m/consumer-unit-10-way-with-isolator/dp/PL10668
The rcbos are dead cheap too... e.g.:
http://cpc.farnell.com/pro-elec/aub1r-32a/rcbo-single-pole-32a/dp/PL10658
However, you can get them cheaper by adding '10' to the product code in the search box as they are currently on offer.![]()
And?I think I've read that Wylex are good but apparently not the cheapest.
Only 'cos I am paying for it.And?I think I've read that Wylex are good but apparently not the cheapest.What's this obsession with the cheapest s**t you can find?
Only 'cos I am paying for it.I stumped up for the Wylex kit in time for the electricity board hopefully to leave me suitable length tails when they fit the isolator today.
I've got the first fit inspection on Wednesday. All of the circuits are broken apart from the 10mm² cooker point radial. The broken circuits are all either 2.5 or 1.5mm². Can I just terminate the broken circuits cables in some terminal block inside the CU until I am ready to connect them? In fact, if I secure the terminal block and have only one wire per terminal, can I make it a permanent fixture in case the cables are too short to reach the RCBOs?
Have you used it?
You are right, no new tails, he simply cut new ends to fit in the isolator switch.The DNO will not provide you with meter tails or an earth connection. That is your responsibility.
Are the bonding conductors the right size for your supply type?
Have you used it?
I didnt realise there was a 2nd page when I posted.yes, that is usually the case especially with stuff like clothes, tools, etc.
Surely products such as consumer units have to be manufactured to meet a set of standards. And this product says it meets IEC60439-3, EN60439-3 of which there are BS equivalents.
I'm guessing the major difference will be longevity/durability (e.g. on cheaper ones the case may become brittle over time with uv exposure, or the main switch will wear out quicker if for some wild reason you switch it on and off all the time.)
That's not to say it isn't suitable, and it will *probably* last until the natural time comes to replace it again (which won't be long considering the number of times I hear of a recommendation to replace a consumer unit which is wholly unnecessary.
Like yourself, I have not used this brand, but I have heard of others using them and not having any significant problems.
To be honest, it looks identical to a Clipsal board made by GET, so it's probably an OEM jobbie.
I am changing accessible water pipes to plastic and the heating pipes will be plastic to avoid bonding. The water supply pipe is already plastic. The 6mm² bonding conductor for the original SS sink runs behind where the boiler will be, so the gas fitters can use it if they want to bond the gas pipe when they install the boiler. The Baxi Duo-Tec 24HE boiler might be less than 0.6m from the sink but won't include a built-in timer (that makes a difference in a bathroom).I am talking about the bonding conductors that connect to your incoming water, gas, oil etc.
What is your supply type?
