First off, I have no idea what I'm doing, so I'm coming to you poor fellows for advice. I'm only really a DIY person when it comes to inside and smaller jobs like replacing taps, plug sockets, painting, small bit of plastering skirting boards etc.
I moved into a house with an extension which has been here for at least 10 years for which I cannot find any planning permission related documents (on the council site). I do have plenty of other planning permission requests from previous owner who did a loft conversion and built another house next door, along with building regs certs.
The extension is unlivable during December-February, it is our living-room and in those months you need to wear a coat and have hot water bottles to sit in there.
I've been considering upgrading or changing its use to try and improve its energy efficiency. The walls of this extension cannot be more than 20cm thick (!) based on my measurements of outside and inside. The walls are made of plaster board and ply wood from what I can see - I'm not sure there are any bricks or blocks used in this, either way the windows and doors are drafty which also doesn't help.
I've been considering demolishing, requesting planning permission to rebuild and turning it into a kitchen but doing all 3 is going to prohibitively expensive and I have about £30,000 max.
My main issue is that it's freezing and we need to sort out the insulation if we ever want to use it properly.
What are my options?
I have attached dimensions and photos (the horror of the wall I'm sure you can appreciate).
Thanks,
Juli
Thanks,
Juli
