- Joined
- 11 Jan 2004
- Messages
- 45,889
- Reaction score
- 3,520
- Country
Read in Scots accent: "No, but think of the cost!"
ban-all-sheds said:That's only 1mm larger in diameter than 25mm - no big deal.mildmanneredjanitor said:35mm2!
Indeed - and it was abundantly clear to the rest of us that 25mm2 etc were csa sizes.kendor said:ban-all-sheds said:That's only 1mm larger in diameter than 25mm - no big deal.mildmanneredjanitor said:35mm2!
If we are talking Current ratings then the Cross sectional area (csa) should be discussed not the diameter and there is a big deal of difference between the current capacity of 25mmsq and 35mmsq
ban-all-sheds said:Even the 50mm2 promised by FWL are less than half as thick again as 25mm2.
FWL_Engineer said:sterose said:Obviously diversity is not being applied properly, because it if drew over 100amps the fuse would simply trip. I find it risible that any house could draw over 100amps at once - even with every single appliance switched on.
It is very easy for this to occur, and it does happen. It is also a bit pressumptious to assume that diversity is not being applied properly.
sterose said:However, it is not presumptious to assume that it's not being applied properly, because, as said, the fuse would simply blow if it got near 100amps.
Although not impossible, how many people have all high-load appliances on all at once. You don't see many houses with a cooker, shower, kettle, hoover, all tv's, all electric heaters on at the same time...
And even then you might only draw about 80amps - which, incidentally, I am aware some company fuses and meters are rated at - but that is besides the point.
FWL_Engineer said:Sterose, on saturday I had my washing machine, Dishwasher and Tumble Dryer on the go, Kettle was boiled to make coffee, girlfriend had the TV on and the garage heating was on at this time due to the temperature outside. For where I live, and many homes in the UK today, this level of loading is not unusual.
Washer 12.8A
Dish 12.5A
Tumble 12.5A
Kettle 12.8A
TV 4A
G-Heat 9.5A
Everything Else about 15A
Total is 79.1A
Now I could load that up even more if it occured at night.
For homes with electric water heating, or electric showers as well, and are a family home, exceeding 100A is actually a real possibility for short periods.
This is why many new heads going in are 125A.
The real problem is that Diversity was great many years ago, but technology has moved on, and the electrical loads we are subjecting our installations to has increased dramatically in the last 10 to 15 years, however the allowance of diversity has not kept pace with this move, although this is the IEE not the sparks.
RTFM first - I did that plumbing once, and then found that even though it had H&C connections, on anything other than the 90° programme it still took only cold in and heated it up. Why did I bother, I wondered...FWL_Engineer said:....haven't got around to getting a hot supply plumbed to it yet!!
