Incomplete Wiring
No colours to indicate which conductor is which.
No labels to indicate which conductor is which.
No labels to indicate which cable is which.
No labels to indicate which switch terminal is which.
No labels to indicate if switches are 1-way, 2-way or intermediate.
No description of what "it doesn't work" means.
No description of how it worked before, and what you changed.
No description of how you want it to work now, and what you have tried.
Excuse the crude drawing but could somebody complete the wiring for me
No chance.
Apols, this was meant to be posted to an existing discussion not a new one.
The Red Green & Black labelled supply are the only wires with current through them. This is connected to to a single light with 2 switches. (Middle Diagram). This circuit works fine.
The issue I am having is in Room 1 I have 2 sets of RBG one for the supply to Room 2 and one for Room 2 switch. I need to connect these 2 RBG to the existing Room 1 circuit and wire Room 2 (Right Diagram) correctly to the light fitting.
Hope this makes sense.
