you probably bought the correct BTU output though.. I bought too small.I have verticals in my home also.
And never had any issues.
The dinosaurs like to put rads under the windows.
for my open plan extension I pretty much doubled the kw/BTU required as I wanted the room to heat quickly. You also want them located where the cold areas will be so they get good circulation. Its possible you can increase the air flow over the existing rads by making sure they aren't blocked by furniture. You could also unscrew the Trv heads a little to get every drop of flow out.
if you have any power sockets near could try a Usb fan to increase air. but it won't make a massive difference.
the easy answer would be an electric heater for the 4-6 weeks of the year when it's coldest
i guess that's because the half circle has more surface area than the flat columns maybe.. link me up would yaoutput does vary by style- i have some column rads which are half circle and they put twice as much out as other column rads. trouble is they cost 3 times more than the cheap ones you can get from the likes of betterbathrooms and victoria plum
Are these shiny chrome radiators ? SHiny chrome does not radiate nuch heat. instead it warms the air in contact with the radiator ( which is not radiating much heat ).
Either use a fan to increase air flow over the radiator or paint it with matt black radiator paint, black objects radiate more heat than shiny objects.
That said the increase in heat output ( if any ) may not be worth the effort
Could this be because all the heat is collecting near the ceiling?designer vertical rads never heat the room properly.
Well this dinosaur has never seen a kitchen radiator below a kitchen window and I have been a gas engineer for a very long time and have seen a lot more installations than youThe dinosaurs like to put rads under the windows.
the maplin thing looks worth a shot.Could put stainless steel corrugated steel behind the towel rail sorry vertical designer radiator,it may increase the radiated heat,could look naff thou.
Could fit foil reflective stuff behind rad,My opinion will look naff. https://www.twistfix.co.uk/radiator-reflector-panels?cat=33136
Could fit a fan to the radiator,will look and sound naff,in my opinion only.http://www.maplin.co.uk/p/radiator-booster-n82nl
Have seen plinth heaters fitted in living room furniture as well as kitchen plinths,just to spread the around the room,maybe the fan action will move some heat from the vertical radiators.
Good luck,
I did add on a few hundred BTU's
I took it all too literally clearly.But btu is a relatively large scale.... A few hundred is not much.
