indesit Di620 integrated dishwasher
2 Apr 2006
Help!!!! Please can anyone give me advice on this dishwasher. It has stopped working & keeps tripping the electrics
It will fill, but then there's a humming sound coming from the bottom at the back. I've taken it out and put it on its side had a little look where I think the pump might be to see if there were any bits trapped in there (it was a red plastic type propellor inside a white plastic case), but it all looked clear.
So I tried putting in vinegar & baking soda with hot water,min case it's clogged up, then it filled up, but then the humming started again and it was full of water...... Then electrics tripped again
Does anyone have any ideas what could be potentially causing the humming noise and ideas what to look for? It's about 8 years old so could probably do with changing, but if it's something fairly simple, I may as well try it!
Many thanks for reading my ramble and thank you for your time
