- Joined
- 13 Feb 2009
- Messages
- 129
- Reaction score
- 3
- Country
My indesit IWF washer, 5 years old at the very most, is refusing to wash.
I've verified the water connection is ok, machine powers on ok. Also cleaned out the pump, which didn't appear to be blocked.
I load the machine, close the door, select a cycle, press begin. After 2 seconds there is a single click, then nothing. It used to start filling with water at that point.
The door lock is operating as expected, because the padlock light is illuminated. (and confirmed it is locked by physically attempting to open it).
Switch off the machine, wait 3 mins, the padlock light disappears (with the same click noise).
Removed the washer lid and observed inside while running through the switch on routine, the click definitely comes from the door lock mechanism.
Door lock mechanism has 2 brown wires and one red wire running to/from it.
Can anyone advise steps to trouble shoot from here? Presume lock mechanism is ok, but the next item in the chain (whatever that may be) is not firing up?
