It’s important to bear in mind that there are multiple design philosophies which were used in an approaches to both persosl
Shock protection and earthing / grounding systems.
Dutch wiring, done to code, is generally very safe.
The key thing is don’t just assume that you can apply approach that make sense in networks that use TN-C-S and apply them in networks using TT or IT grounding approaches.
Things like bonding to pipe work isn’t always advisable or safe. You could be sending stray / fault currents into gas or water mains or even picking them up.
If you’re upgrading that building’s wiring, it’s likely the whole system would need to be reviewed and redesigned, not just hacking an Earth / ground connection to a single room or outlet.
