Hi, I have bought replacement appliances for my kitchen and I will install them in virtually the same place as the existing double oven and ceramic hob, so the position of the existing wiring does not need to be changed. However, I am unsure if I need to get an electrician in to change the wiring configuration.
Current wiring:
From the mains board, on RCD circuit, one 6mm^2 T&E cable runs through the ceiling to the kitchen and terminates in a cooker switch. The fuse says B40 on the mains board. From the cooker switch one 6mm^2 T&E runs into a round brown junction box and from there one cable runs to the double oven and another runs to the hob. Does that all sound ok? I was a bit surprised to see an ordinary junction box?! This wiring was done by an electrician 19 years ago.
Required Wiring:
To replace the double oven I now have a separate combi microwave and oven and therefore two cables to accommodate (plus the one from the hob). I have been reading numerous forum entries but I cannot find a definitive answer. I don't mind calling an electrician out, but if it is as easy as running another cable into the junction box then I am more than happy to do that (presumably that does not fall under ceritifiable changes?).
Power ratings:
Combi microwave 3kwh
Oven 3.4 kwh
Induction hob with extractor 7.62 kwh
Your advice would be really appreciated!
Em
Current wiring:
Required Wiring:
Power ratings:
Oven 3.4 kwh
Em
