Induction hob wiring
deadshort";p="3379242 said:
Hi, you just need to replace the cooker connection plate with a dual connection plate. If you're oven requires a 13a fused supply, then put a 13a FCU or Socket onto one of the 6mm cables you have connected to the dual plate.
I would use 6mm or 4mm to supply the socket, that's just my preference. :) Simply because -
The oven wiring is 6mm and i would leave that in place to make it easier to install a more powerful oven if and when required, all that's required is to remove the socket and connect. As i say, that's just my preference.
Kind regards,
DS
Will need two metres, then. :)
And if you want to upgrade to a more poweful oven why could you not just connect it straight to the dual outlet cooker plate you recommended? What are you going to replace the socket on the end of the 6mm with? Another outlet plate? :roll:
So if i understand you, what i propose is fine?
Not necessarily - we have yet to ascertain what size the present flex is. Of course, anything less than 2.5mm² (and what you have will almost certainly be smaller than that) would not "be fine" in terms of the manufacturer's instructions - but that may not worry you.
Kind Regards, John
The oven ? ffs
DS
The oven ? ffs
Oh. Maybe I misunderstood. Are you suggesting that the outlet plate should, now, be connected to the socket about 6 inches away with a couple of metres of 6mm² T+E, and that that T+E should be disconnected from the socket and wired directly to the hypothesised future oven if/when the time comes?
Kind Regards, John
Oh I see so there's just going to be a nice big loop of 6mm in between a socket and outlet plate just in case, in the future, at the end of this ovens life, the OP might want a bigger one? ok then
OP, just buy a few meters of 2.5mm (if following manufactures instructions) or 1.5mm if you're being sensible, I would go with butyl type cable to be on the safe side
you could use
http://www.screwfix.com/p/heat-resistant-flexible-cable-3093y-3-core-1-5mm-x-5m-white/76347
or
https://www.tlc-direct.co.uk/Products/CA1dot5TQ3slash50.html
both are heat resistant, the screwfix one is PVC though, not butyl (but both heat resistant)
As I've just written, that's how it seems! If I practised that sort of very-long-term speculative 'future-proofing' in my house, goodness knows how many 'big loops of cable' there would be all over the place :-)
Kind Regards, John
Kind Regards, John
Ye, future-proofing is for the young.
Kind regards,
DS
My future proofing is things like CAT6 to every room, more socket outlets than you think you'll ever need, loads of spare ways in a CU, not looping cable at every opportunity
Great, is it a plastic CU :shock:
DS
Kind Regards, John
Yes, the manual specifies 2.5mm for connection via a socket outlet, but the consensus here seems to be that anything over 1.5mm is overkill and also awkward to wire into a plug. Presumably the same dilemma applies to the length of flex connecting the connection unit to the 13a socket on the wall.
Or maybe i could use something like this http://www.screwfix.com/p/1-gang-45a-cooker-control-unit-white/3285d
But no-one has challenged the principle of running an induction hob and a 2kw oven off the connection unit in the picture, using the 6mm cable for the hob. So it seems a safe and sensible approach at least.
