- Joined
- 20 Apr 2021
- Messages
- 49
- Reaction score
- 2
- Country
We've purchased a hot tub and are getting a socket installed outdoors to power it from.
I'm not DIYing the socket, but I'd like to be armed with the best solution when I get an electrician in because I know it can be a tricky job with lots of pitfalls and risky shortcuts. I'm a bit paranoid about sitting in a tub full of water that's plugged into the wall as it is
Hot Tub Power details (Lay-Z-Spa Cancun):
- Is there any kind of specific waterproof socket type/cable/in-line protection we should be asking for?
- Should I be requesting it goes on it's own circuit separate from all other devices?
Our circuit box has a switch specifically marked 'Outdoor Socket', and this goes to a loose cable already outdoors which we had temporarily capped while we were landscaping. I assume this means it's on it's own circuit and that'd be of use to the installer who can run it underground up to the right spot on the outside wall of the house? As it's an unknown cable doing unknown stuff, would it be best to ignore this and ask for a new cable entirely?
Sorry if these are dumb questions, but - safety first and all that.
Big thanks in advance for any help
- Voltage - 220-240V~50Hz, 2,050W at 20°C, Class II
- "all Lay‑Z‑Spas are designed to plug into a standard UK 13amp/240V electrical supply. We advise that you always use an RCD protected socket (like those installed in your home) and not an extension lead."
- There's a PRCD box with 'reset' and 'test' on the cable
