And have you checked the airflow?
Unless the fan can draw air into the room, no fan will improve matters
Thanks for all your advice. Would it be worth me getting the electrician to swap the white flexi duct at the outlet side of the fan for insulated flexi ducting as I have some spare?
Thanks Murdochcat. The bathroom is fully tiled so can be quite cold unfortunately.
Just out of curiosity if you were using rigid pipe would you insulate it too? I've seen people mention covering it in insulated flexi hose.
