Yup https://www.vent-axia.com/domestic-fan-installation-compliance-checkerAre they recommended when they have 1.4m of ducting to go through?
I find it very hard to believe anyone would recommend one of those extractor fans if it was doing anything but going straight through a wall.
What does the TLC fan size calculator recommend?
Almost all of that type have literature stating that that length of ducting won't be an issue unfortunately.
not easily. I think for now short showers & larger gap under the door is the temporary solution. At a later date I will take up the loft floor board but unfortunately as per the pic below, the loft floor stops a good metre or so short of the ducting and it doesn't look like there is much crawl space to work with.Can you get into the space above the ceiling?
For at least half the year I'd be making the matter worse not to mention the cost of letting re-heating the room each time. Re fan placement, I tried to place between the bath and the shower for that very reason but alas, not good enough. Inline fan is the "proper" solution, just wish it was more commonly recommended. Even searching back on this forum, vast majority of recommendations are for the type I've installed but I guess the caveat is, they are absolutely fine for "normal" shower use, just not for teenagers!I can't see why you just would not open the window! There is no better way to get ventilation and better air movement and reduced pressure for the fan, and better than any crappy 10mm door undercut. It's just so simple.
Probably too late now, but the fan or input should have been placed over or near to the shower or bath (better extract at source), and perhaps should have been an inline centrifugal fan (most efficient) with a 125 or 150mm flexible duct and no sharp bends (smooth massive air movement).
So unless those are to be altered, the window is the only practical option.
