Inset tile to wooden worktop
7 Sep 2006
London
I have a ruined wooded worktop where water from the sink has rotted the wood. As a short term bodge I am thinking of insetting a single 1200x600 tile, which would fit perfecty. The idea would be to use a router to create a tight fitting recess such that the tile lies flush with the rest of the worktop.
I will need to cut a shape in the tile for the drop in sink, with pretty tight tolerances. I'll also need to mount a through-worktop mixer tap.
What I don't know:
What adhesive to use under the tile.
What sealant to use around the edges of the tile
How to cut the hole for the sink
How to mount the tap tightly enough without cracking the tile
Other things only an expert would know!
I realise I should really rip out the whole worktop, but in fact there's another 4m of lovely maple that I don't want to lose.
Can anyone advise?
I would advise against it , (unless you have a good supply of free large tiles)even if your cut out is successful just picking it up to install is likely to break it given you will have a hole for taps a few mm from edge of tile and edge of cut out .
I see. What if I made the cuts with the tile already in place so that it was supported?
Alternatively, can you suggest another material that I could do this with?
I guess a 'high pressure laminate' eg Trespa Meteon would work but not cheap, there are other manufacturers. It's typically used as an exterior cladding but it's also used for toilet partitions amongst other things so only available in massive sheets or you pay a premium for having it cut to size etc. eg https://plasticsheetsshop.co.uk/hpl-sheets/?fwp_paged=2 you need to enter the size you want to get an accurate price, looks like you'd be paying about £80 depending on the colour and what extras you added.
Interesting stuff - not much more expensive than a tile @ 6mm, which would be a perfect depth to recess in.
I'm now wondering if this might be better managed by pouring an opaque epoxy resin into the recess.
Just wondering... If the worktop depth is 650mm, would you be able get the router close enough to the wall?
Any water jet cutting places near you? They'll make a nice accurate job of cutting the sink hole in a tile, or the material FMT has recommended - WilsonArt Zenith and Sheridan Apollo are other brands I've used often. Finishing the edges will be easier with compact laminate than with tile
