Insinkerator 3n1 tap leaking can it be repaired
They just said an internal fault . Leaking from where the base joins the swivel pipe
Thanks for all your help, sounds like ours is the same then.
ohhh.... I have a similar boiling water insinkerator tap (mine has the glowing button for filtered water).
A 7 or 8 year life span doesn't sound very encouraging...
BTW, do you find the boiling water a tad cooler than it should be? I work in quite a few houses, the Quooker water seems to be hotter. I prefer the push down lever configuration of the insinkerator over the double push collar set up on the Quooker.
