Installation of honeywell CMT921 RF thermostat
23 Jul 2007
Mid Glamorgan
I have just bought this honeywell RF stat and looking through the installation manual I cannot understand the wiring arrangement for the receiver, I am going to use 2x 2 core heat flex cable (1 for the voltage free switch and the other for L&N).
Anyone installed these willing to share the diameter cable used for each connection, the manual seems to point towards 1.5mm - 2.5mm core for the L&N with outside diameter of less than 7mm, whilst the voltage free switch of greater than 7mm.
I am connecting to a 3amp protected combi boiler, any idea on cable size?
Rgds
1 4-core would be a lot neater. if manual says you must use minimum 1.5, than that is what you need to get.
