The light, the big lump on the ceiling, was it heavy when you put it up .
it is most likely a wire wound tran as steve said.
This is an inductive load (VA) you would need a dimmer that is
either 250VA or 400VA rather than 250W or 400w from there B + Q range.
However it should have worked for a limited time even if wrong.
I take it you pushed the button for ON and OFF
