Hi- want to install a PIR for the external light which is currently mounted in a porch / covered area by front door. The current light has 3 cables coming, one being switch, as two are not used for the light - seems to be common earth and neutral and live (except switched live), I'm going to isloate these onto a termination block which should be OK.
The instructions for the PIR - and all other insturctions / warnings I have seen - recommend install a fused switch, I was thinking of doing this by putting an external IP56 fuse block mounted inside the porch area - is this OK / legal ? Then run power to this then to the PIR and then to the light.
