I want to install an over the bath "power shower" (A shower unit with an integrated pump) I am thinking of:
The Mira Event XS Thermostatic Shower
I have not yet bought it so any comments about this shower or other "power shower" recommendations would be greatly appreciated.
I have had 4 plumbers in who all want to supply the shower by teeing off from the bath taps. This house has chronic problems with trapped air in the central heating system, which I would rather not have transferred over to the new shower but when I insist on having dedicated hot/cold feeds to the shower to avoid this they all beg off saying it's too much work and try to undermine or bully me into teeing off the baths (as it's easier for them) . I don't see why I should be made to feel silly for not being prepared to fork out money in the hope that "it will all work out fine", when I am prepared to pay a bit more for it to be done properly in the first place, I might still have an air problem either way. but at least I'dve done all I could to avoid it.
Anyway I have had enough so I am gonna try to install it myself (Just the plumbing not the electrics I am still bloodied from crossing swords with Part P during a kitchen refit and have no desire for a rematch) I have spent the last few days reading through the posts on this forum and so have "some" idea of what I will be doing but I would like the experts to go over my plans and let me know if I am missing anything.
My setup is as follows:
The hot/cold tanks are in an airing cupboard approx 5m away (as the crow flies) from the bathroom and 6.5m (as the crow flies) from where I would like the shower to go.
The route I would need to take to get the water from the airing cupboard to the shower is 10M long and would go under the floor to the bathroom then up the wall to the shower.
The system is gravity fed from a ~50 gallon cold water cistern that is ~1.9m off the gound. This supplies a 140L hot water cylinder that sits 80cm directly beneath it.
Cold water is fed from the cistern into the bathroom via 22mm copper pipe. The cylinder is supplied by 22mm copper pipe from the cistern and feeds hot water into the bathroom via 22mm copper pipe which comes out of the cylinder horizontally before teeing off vertically to the vent pipe and the pipe that leads to the bathroom fittings as illustrated below.
After reading the instruction manual & some of the posts on this site and talking to Mira I realise that the two biggest problems I face are:
1) That the average shower unit is placed ~150mm off the ground. With such a low cistern only 186cm off the ground and such a long supply pipe run ~10M maintaining a sufficient enough head for the shower to operate without reduced flow rate, spluttering and temperature
fluctuations may be a problem.
I want to use 22mm JG Speedfit Barrier Coil Pipe with the 22mm Cold Form Bends to do without elbow joints all the way up to the shower unit and then step down to 15mm with a JG Speedfit 22mm-15mm reducer and then connect to the inlet port on the shower with either 15mm JG Speedfit Rotating Elbow Stem or 300mm/1000mm Long Speedfit Flexi Hose.
This way will require less pipe and will mean that I won't have to put any connectors under the floor where I wont have any access to them should they fail.
2) The low cistern head/horizontal orientation of the pipe leaving the cylinder will increase the risk of trapped air and cavitation Mira recommends installing air vents to help resolve this is there anything else I can do?
[Updated as I accidentily submitted before I was finished]
