Not so much an electrics question but more "how do I install an outside light with the minimum destruction to my walls?"
I'm installing a lamp outside my front door, under a porch. Taking power from a switch just inside the door (converting to a 2gang to control inside and outside lights). I can't install the light on the other side from the switch as it'll be too low down the wall. Am I going to have to accept that I'll need to cut a hole in the wall in order to feed the cable through?
Wall construction is (out-in) facing brick - cavity - kingspan - thermo block - dot and dab plasterboard.
The cable to the light switch runs down a conduit between the thermo block and the plaster board, but I can't tap into it without starting to chop holes in the plaster. Or can I?
