- Joined
- 16 Jun 2009
- Messages
- 2
- Reaction score
- 0
- Country
Hi all
I am nearing the completion of my decking and wanted to install some decking spotlights. I have some limited electrical experience and realise this work falls within Part P regs etc but wanted some advice.
I want to run 10 spotlights via a socket with an outdoor switch to knowck them ona and ooff. The switch will be connected to the lights via 0.75 mm pond wire and to a depth of 600 mm under the ground surface. The live power to the switch will be via a fused spur conncected to a socket in the kitchen.
Will the 0.75 mm cable be sufficient to run 10 lights? They use 50w GU10 bulbs.
