Due to the nature of our kitchen re-fit I have to install some temporary cabling (in place for 2 or 3 weeks) from the supply for the double-oven. The supply itself is fine and reusable, I just have to move the cabling around. I have a few safety first questions.
1) Assuming I use a suitable junction box, is it okay to join cooker cabling (6mm or 10mm). I notice the DIY sheds don't stock them but my local shack has a beefy 60 Amp one.
2) Should cooker cabling be kept a certain distance from other services, eg hot water pipes and other mains cables?
2) Is it permissible to install the cooker control unit (and the terminal outlet plate) into a plastic surface mounted box? Or should these things always be in flush metal back boxes?
3) Is it permissible to have the cooker cabling surface clipped to the wall or temporary that it is, would it be better to put it in conduit?
And a real dibbo question. If a faceplate (of any type) has it's earth conection joined through to the ring earthing, why does there have to be a seperate back box to faceplate earth conection made too? Why do plastic surface mount boxes have an earth conenction but dry-lining boxes don't?
Many thanks. I have young children in the house and don't want to get this wrong.
Regards,
Robert
Regards,
Robert
