- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
I want to add 5 LED downlights in the kitchen. There is currently a ceiling rose light installed.
I've done quite a bit of research (not to mention I've done it before many years ago but can't remember a bloomin' thing!) but can't quite find the exact and non-conflicted answers but hope you can answer them:
Thanks and hope you can help.
- It seems 1mm cable is fine but if 1.5mm is already being used must I keep it consistent?
- It seems a junction box is needed whereby the 5 downlights are all (parallel) connected to it along with the ceiling rose. If so, which type of junction box (can I simply use a large chocbox?) should/must I use? If you can put a link to one please that would be great.
- Can I put the junction box on or between a ceiling joist or must it now be visible for access at all times? Someone has suggested it needs to be put somewhere on the ceiling such as next to the ceiling rose but surely that spoils the appearance?
