Hi all,
I am wanting to install a dishwasher in a kitchen which doesn't already have one. It will go under the sink on the opposite side to the washing machine. I would ideally like to connect it up without disturbing any tiling.
I currently have one 13A FSU above the washing machine with an unswitched socked below. The FSU I assume is on the ring main as it has 2x2.5mm feeds with 1x2.5 supply to the socket below.
I am aware you cannot connect more than one appliance into a single socket/spur, so I was wondering if there is anything I can fit in lieu of the FSU which will act as 2 FCUs supplying 2 spurs down to 2 sockets below? The hope being it can be a straight swap!
Apologies if there is an obvious solution to this, I'm kinda new to household electrics
On a side note regarding plumbing, I was going to buy one of these http://www.screwfix.com/p/washing-machine-y-piece-bsp/81000 and also one of these http://www.screwfix.com/p/mcalpine-appliance-trap-40mm-white/95241. I trust they will do the job?
