Hmmm. I was merely responding to the concept ('red herring'?) you introduced of 2 x 2.5mm² cables being equivalent to 1 x 5mm², wasn't I?Yes, I know all that but you are introducing red herrings.
As you know, some people do query that - but, as you say, not me.No one would query two 2.5mm² from close points on the ring; you have suggested two spurs from the same point.
I agreed that it was electrically OK (as OK as two 2.5mm² cables attached close, or at the same point, to the ring) - but, when I first commented, I did add that there was going to be debate about whether that re-compliant (which is when BAS jumped in and said that there was no scope for debate, because it was non-compliant!)Because there is conduit in place I have proposed 4mm² and, even though you actually agree, we have ended up having a prolonged discussion although it was BAS who disagreed and it was to him that my justification was aimed.
I think that we (including BAS) are all agreed on that.There is no doubt that my proposal is electrically safe.
That, coupled with the fact that it is clearly electrically OK (as above, as OK as 2x2.5mm² 'close spurs') is the basis on which I personally believe that it can be said to be regs-compliant - but, as you say, that is the debate, and there are clearly some (and probably not just BAS) who disagree.The debate concerns whether the regulations allow it or not because they do not expressly show it - but then - nor do they expressly forbid it.
Kind Regards, John ²
