The dimmer needs to be compatible with the transformer in the light fitting.Is this correct that we need to buy a Next halogen compatible dimmer, or can we buy a third party dimmer?
You don't need to buy a dimmer, you can just use the light undimmed.
If Next supply such a thing, then get that one - assuming you believe that they actually know what is compatible with what.
However if the transformer has the word 'eaglerise' on it, then the only course of action is to remove the transformer, throw it away, and fit a decent one.
Or as already suggested, it is obvious that the ceiling in your house is far too low to accommodate such a light fitting, therefore returning it and obtaining something smaller would be the better plan.
when the product is in operation, the transformer makes this high pitched, constant, sound which isn't overly loud but is definitely noticeable in a quiet room.
The "transformer" is a switched mode power supply unit SMPSU. It operates at around 40,000 Hz. a real transformer operates at 50 Hz, real transformers can hum but not whistle. Good transformers don't even hum.However, when the product is in operation, the transformer makes this high pitched, constant, sound which isn't overly loud but is definitely noticeable in a quiet room.
How many dimmers are SMPSUs?You probably can't hear the 40,000 Hz tone but if there is another SMPSU involved ( like a dimmer )
