(I am not a spark so quick q: Yes, they could be on different circuits and the OP needs to check, but wouldn't that be an existing compliance issue? I thought having multiple circuits in the same accessory was a regs no no? Hence no borrowed neutrals etc?)
I dont recall anything forbidding it, though its more common in mutigang switchbanks and often in commercial, 2 or 3 phase 400v can be found.
I quess the onus is on the person removing the switch knowing what to expect and testing.
Borrowed Neutrals should not occur, as the relevant Neutral should, in the OPS case still be on the same relevant circuit.
Though, in the OPs case if he did feed the Lightwave using just one of the circuits and capping off the second circuit, he would indeed then cause a Borrowed Neutral which is forbidden.
In the OPS case, if theres no other way to get round it, he could maybe alter the backboxes to fit a Two gang lightwave and a 1 gang lightwave.
1 gang switch :
Disconnect the 3 core (brown/black/grey) completely.
Brown and blue from the separate cable connect to the switch L and ~
3 gang living room switch:
The two separate browns connect to L, the blues connect to the right ~ and centre ~ terminal. Nothing connects to the ~ terminal on the left.
The 1 gang switch controls the light, the left gang on the 3 gang switch will need to be programmed to also operate the 1 gang via the app.
Does that not Link the "Spare room and the "Living room" together, that are 2 seperate circuits, I read it that the 2Way Passage was on one circuit with the spare room
