Perfectly acceptable isolation valves, no need for the dramatics of the above ridiculous suggestions unless it was in a commercial setting.
for domestic use they are more than adequate
Not for me they're not! I like to know that something can be isolated without having to drain the whole sodd1ng system down because the service valve was fitted by a *****.
Another thing that really p1sses me off is having to spend more time preparing/finishing a job than the actual job itself.
Sorry, I shall alert the media & have them withdrawn immediately.
Best whip down to B&Q & Wickes, have them clean off their shelves. What do you monkeys use when fitting wash basins/ toilets etc
Don`t make me laugh.
Peglar Bulldogs. If they need to be less intrusive the handles come off and the valve turned 180 degrees. Handles then either put back on or taped to the pedestal.
