Do you mean logging in as engineer and pressing reset? If so, yes but still get the message.
I did a power down, and back up holding the reset button after flashing, but not since adding the Smartcom or removing the COM2400, should I do this again?
Ah, that’s right. I defaulted the panel after flashing.
I have logged in as engineer and pressed reset twice which logs me out but still get the message
what version firmware are you using? does it display all the time system alerts or just ATS when your exiting engineering and reverts to time and date?
You can try engineer utils reset digi.
come out of engineering, if that doesnt work you can try a power cycle, ie remove battery, remove mains replace battery put mains back on, update the time and date.
if after that the fault is still showing it needs investigating more deeply.
