Hi guys. After much advice on these forums, I'm well on with a stud wall in our single skin outbuilding.
A couple of images....but I know you guys know what a stud wall looks like
The battens will have 130mm kingspan between them, with a 30mm breather gap to the wall. On top of the battens & insulation ill have a membrain, and then the plasterboard.
Im starting to think abotu where we want switches and sockets, and just wondered what you guys would suggest regards running cable. I guess I dont want the cable behind the kingspan attached to the wall, as that would mean compromising the kingspan. So my options are;
1. Inset the kingspan slightly to create a gap between the kingspan and the pasterboard. Drill holes in the battens and run the cable on top of the kingspan. Would however mean chizzeling out a recess in the kingspan to fit back boxes.
2. Run along the wall, and drill a hole in the kingspan to pull the cable through, also chizzeling out for the back boxes
3. Fasten the cables to the wall, and bring it to the front via a hole in the battens (front to back).
Id also love to know if you would suggest using noggins to fit metal back boxes, or use plastic?
Any suggestions appreciated.
