I suppose that's strictly true, but I think it could be an uphill struggle to invoke and support that argument if one were ever challenged.
I don't. It would be hard for anyone to argue that fitting the "103 curve" to other installation methods where reason says that the same
principle of short-length considerations must apply was actually unreasonably careless and lacking in skill. And therefore it would be hard for anyone to argue that if I had done that that I was wrong to say that to the best of
my knowledge and belief, i.e. that to
my mind it complied with BS 7671. Remember - the declaration is not an assertion that what you have done does comply in an absolute fashion, it is a declaration that to the
best of your knowledge and belief it complies.
And anyway - the only circumstances in which a challenge of any significance would arise would involve considerations of reasonable doubt.
I do sympathise and empathise with your approach, which corresponds with common sense and pragmatism.
It corresponds with what the regulations say, with what the responsibilities of the designer are, and what he may say about the way in which he has discharged those responsibilities.
Would you similarly argue that (all other things being appropriate), say, a 4mm² unfused spur from a ring final supplying multiple sockets was compliant,
You'd have to show that you had exercised reasonable skill and care in ensuring that what, from the POV of the ring final, was a load at a single point, was not likely to result in the ring final cables being overloaded for long periods. I've not given any thought as to how easy that might be, but there is nothing else which prevents it. 433.1.204 requires a
minimum of 2.5mm² and a
minimum Iz of 20A. If (all other things being appropriate) a 4mm² spur doesn't need an FCU then it doesn't need one, and no regulations are contravened.
or that a 1.5mm² cable from a ring final to an FCU was compliant?
If it's 2-core MICC it is. If it is any other sort of cable it is not - 433.1.204 is explicit about that.
