- Joined
- 28 Oct 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi!
I speak to you as a noobie who has just bought his first home with his fiancee in the Forest of Dean, Gloucestershire.
It's a rubble walled place estimated to have been built in the 1860s.
I've just started the demolition process, ripping down all the lath and plaster and the lime render off the walls.
Obviously, in the not too distant future, we're going to be building the walls back up, and we're now looking at insulation.
I've been told various things when it comes to this. First being that I should use a vapour membrane directly on the walls, then studding, then celotex insulation, then plasterboard.
I've also been told that the stone will need to breath and that by doing the above, I will risk damp entering the building and that I should only use lime render, inside and out.
In my mind, this won't provide enough insulation.
We want to be as green as we reasonably can be, using as little energy as possibly to heat it; underfloor heating, possibly heat recovery ventilation.
Our house has evidence of damp since our first viewing 7 months ago. It seems a fairly new roof has dried the place out a treat, so I'm not sure if damp would really be an issue...
Any advice would be brilliant!
Lee
Lee
