Hi I have a typical draughty 1930's house with suspended floors and I understand a fair bit about insulating the ground floor. We have air bricks back and front on both floor levels and of course it gets pretty draughty under the ground floor and there is a void of about 10inches under the ground floor joists but what about the 1st floor?
I am not sure how the air bricks can do that much on the 1st floor as the joists are sandwiched between the ceiling below and the floor above so surely they can only ventilate within the 2 joists that they are located what do you think?
I am thinking of insulating the 1st floor as I am decorating there now. I realise that some heat may come up from below and insulating will stop this but surely this is a good thing, as heat from below is lost heat below and the air bricks in the 1st floor will be allowing cold in so insulating from this and thus preventing so much heat being stolen from below will be a good thing, wont it?
I was trying to find a good thin insulator with a good R value that I could place on top of the floorboards (and not create too much height) but other than a really crazily expensive one none seem that good so I then considered putting in Kingspan just under the floorboards, which would be a lot of work but seems my only option to insulate well, any ideas?
What do you think about me insulating the 1st floor, good or bad idea and reasons, any advice appreciated.
