Ok I have purchased a house recently and have had fire rated GU10 down lights fitted into the master bedroom. It is now winter and there is NO insulation in the loft and im freezing my arse off so want to move forward with insulating my loft.
To summarise:
I have 3 bedrooms upstairs only and no bathroom (downstairs bathroom).
I had a new plasterboard celling put up as the old one was falling down (soft woof material).
I have had 7 GU10 fire rated downlights fitted to this sealing
I have fitted 7w LED lamps to each of these downlights to reduce heat and of course save on electric bills.
The other 2 bedrooms have a centre ceiling light fixture so nothing is in the recess and thus no need to worry about heat from these fixtures and having to ventilate.
My joists are around 100mm deep
My plan is to use 50mm thick Celotex cut a few mm larger than the width of the joists (which are 400mm) so that they fit tightly in each of the ceiling joists and sit on top of the plasterboard ceiling. I will then cut a generous hole leaving around 50mm or more around each of the 7 down lights. I will ensure all cables are left on top of the Celotex and not in-between the celotex and plasterboard ceiling. I will then board up the whole loft
This will leave a 50 mm gape above the celotex and the top of the joist (where the loft board starts) giving the heat from the downlight plenty of ventilation.
Once the loft is fully boarded I will then ideally cover it in 100mm thick Celotex so that we can use the majority of the loft for storage. Depending on cost I may just lay thick roll of rockwool on top of the boards rather than the Celotex but I will see how I get on come the time.
So will this solution safely work with my LED downlifghts and provide sufficient ventilation and safety.
Cheers,
Mike
To summarise:
Cheers,
Mike
