In still undecided on celotex or a mineral wool but which ever I use I'm worried there will be insufficient space to run elec and plumbing above the insulation so can I run this beneath the insulation in the sub floor and then up through the insulation? Wound this cause a fire risk as it would be coming through insulation.
If you use 50mm Celotex and set the top of it an inch below the tip of the joists, that should give you enough room. Alternatively I don't see why you shouldn't run it underneath as an alternative, and it won't create a fire risk if it comes up through the insulation - you may be thinking of the effect of burying cable in insulation, which reduces its capacity safely to carry current, but this won't be the case when coming up through 50mm of Celotex.
When I did my ground floor I ended up with a bit of both - new cabling was clipped to the joists above the top of the insulation, but I also left some in place within the underfloor void.
Yes, I think so. My floor is less cold underfoot and I don't get draughts. It depends on your notion of hassle. I've been doing a major renovation for the past several years, so lifting an entire floor didn't seem that problematic.
