So he is going to come and lag them?
Considering how lazy the install looks. You sure he has used pipe inserts.
They might not leak straight away, that's the problem.
Remove one fitting and look in the pipe, obviously not easy if the system is full. But it's an area they skimp on because it's not easy to see there missing until it starts leaking.
If I weren't doing mine myself I wouldn't trust anyone unless they had some pride in their work.
It takes a lot of care and attention not to miss one!
Problem is you cannot tell without taking a joint apart!
They can then fail at ant time, including years later.
But more of a problem on mains water where high pressures can be experienced. On CH systems the pressure rarely exceeds about 2.0 bar when well operated and maintained.
Tony
Does this brand of pipe have the barrier in it? Should be able to check that written on the pipe.
One last thing to check.. there are two types of pipe lagging "economy" and water bye law 49 compliant. The economy is cheaper and less effective.
I thought byelaw 49 related to sewage?
https://pla.co.uk/assets/byelaw49draftwebguidancenoterev2.pdf
If you wanted to fit quality tube insulation you'd be using armaflex.
