Hi all,
Quick question I hope someone can answer.
I have laid all of my insulation down in my room and got the floor all level.
How do I finish it off now?
Do I need a Vapour Barrier or DPM before the floor boards or do they sit straight on the PIR Insulation (Kingspan)?
I have a DPM below the PIR already but given it will be a humid little room, I am not sure if I should add another layer on top?
Also, am I OK to either expanding foam, and / or add Aluminium foil over gaps to seal it all up?
Thank you!
Thank you!
