Err - no, they re supposed to be sealed.The nICC guy said before he gave me a certificate i had to cover them, and advised me to make a box over them , made out of plasterboard and drill some holes in them for ventilation.
Err - no, they are supposed to be air-tight.so i got some plasterboard, made them into a box and places over the downligters. i drilled some holes at the top of them to let air escape,
Err - no "could", you must cover them or you'll have large sections of ceiling with no insulation.then laid the insulation up to these boxes (u could lay over them).
Yes, but he clearly didn't know what he was doing.he then checked them, said it was fine
Only if you regard an ignorant NICEIC electrician as someone who polices the Building Regulations...Sounds like the consensus from those who actually police building regs then is that this is a perfectly acceptable solution.
Not in the slightest no......sounds like the consensus was not to take your advice.
The reason that you didn't bother to read that was what, exactly?
Except that you fail to meet any of the building regs that covering the downlighters is supposed to meet.i dont think u can go wrong with the way i did it....
when making the plasterboard boxes make them so they fit snug in between the joist spaces (that way they cant move about)
Shouldn't be necessary if the boxes are large enough.the reason he said to drill some holes in the plasterboard was to let any heat generated by the downlights naturally escape. they are only very small holes made by a small drill piece.
No, it's a bad thing as it means heat will also escape from the room below.however i understand ban all shed saying not to allow ventilation, but the way is see it, that if a little hot air escapres from within the cover its a good thing.
No - they should be completely sealed with a bead of silicone around all the edges.when making the plasterboard boxes make them so they fit snug in between the joist spaces (that way they cant move about)
i used PB Screws and gaffa tape to help secure the edges on the PB.
No - the insulation should cover them.after they will just look like a little square hat, put them over the downlighters and lay the insulation up to them and job done.
No - see above about making the boxes large enough.also drill a few holes in them so heat generated can gently escape via small drill holes in the PB. the holes shud be smaller then yr finger size.
I think you'd spot the hills in the insulation just as easily.reason i didnt lay insualtion over the PB boxes, because i sometimes store items in loft, and walk around up there. with insulation not going over the top u can see exactly where they are, and no funny mistakes can be made.
Doesn't matter - it doesn't comply with Part L.this little area of loft space wont really make no diff if its not insulated, do the maths
Given in error by someone who didn't know what they were doing.anyways i know now the loft is secure and safe with the downlighters, and was passed and a certificate given.
Depends on whether you think not doing it right equates to doing it wrong...everyone has their own way, but i dont think u can go wrong with the way i did it....
That contravenes the Building Regulations.1. Leave a gap in the insulation and accept the heat losses?
Let's not get back into the argument again (although I would be interested in seeing what the regs actually say ... where can I find the relevant document? Citation please?)
My question has not really been answered. If I do decide to take out the downlighter (which decision I have not made yet ... how do I go about invisibly mending the hole?
