I've been trying to decide what the best cost/benefit insulation is for insulating under the ground floor of my c1900 house. Suspended wood, joist 170mm deep, width between joists 230-370mm, 2' crawl space, but only small(2'sqr) access.
Glass mineral wool seemed the best option as its cheaper and thickness is not an issue. However a couple of doubts...
1 Does 'encapsulated Space Blanket' have an advantage over standard roll (other than comfort while installing). Since the void is very well ventilated does mineral wool lose value if against moving air (as opposed to a nice 'still' loft). Or would using garden permeable membrane to hold up the insulation have similar effect. I have read a post that suggested insulating over the joist as well (but reckon this might risk damp)
2 Is Branded mineral wool really better than say, Wickes own brand (as they don't give a U,R value)..
3 I have read that you should not place mineral wool against the end brickwork (due to moisture). Is this true and what is best to use if it is?
4 I might decide to put Hot Water UFH in one of the rooms (so would be fitting from above for that room). Is solid insulation preferred in these situations, or is solid only used when wool depth required becomes impossible.
5 I also read that solid blown insulation properties degrade more quickly than mineral wool ( due to gas escaping).
Cost is a factor, but I only want to do it once and well!!?
All comments welcome.
