- Joined
- 7 Jan 2007
- Messages
- 8,831
- Reaction score
- 1,230
- Country
Meters are not usually located inside they're usually located in an external meter stop tap box so the water meter reader man can read it irrespective of someone being at home or not.You are responsible for pipes on your property.
Usually a meter is located inside, so if the burst occurs on your property but before the meter, you are still responsible for the repair.
Some water authorities may, or used to, offer a repair service, but a) it is still your responsibility and that may charge you for the repair, and b), they may take weeks to fit it into their schedule.
To the original poster Usually every house has an external and internal stop tap internal it's usually under the kitchen sink ...not always but usually . Have one fitted and above it have drain off. So in future turn off the water internally, open all the taps hot and cold flush the wc's and when all the water stops running using the newly installed drain off drain the last of the water off from the pipework using a hosepipe to outside.
No claim from your insurers will be paid unfortunately.
