integrated aeg fridge freezer not working well
jj4091, JohnD, thank you for your assistance.
This issue can be regarded as fixed now (I hope), we'll see if it happens again and repeat the defrost.
Regards from Terry.
I use an electric fan sat on a stool to defrost our freezer, takes about half hour.
Eocaro,
To answer your question, the drip tray is often located on top of compressor motor. So then heat of motor speeds evaporation of water out if tray into the air.
Sfk
nauseous, good idea I'll try that next time if there is a next time! - Terry.
SFK ah, I wonder if that's accessible from in front through the panels inside the freezer? Maybe one for next time. _ Terry.
When I repaired mine I applied vaseline around the fan to stop ice build up and cut vent in lining larger to allow more air past fan.
If it’s intergrated a poor fit of the outer door can cause problems as it prevents inner door closing completly.
