Intermediate Switch(es) Required?
You've got room for a single-width accessory, and the Scolmore minigrid has a 3-gang single width, or you could fit a double-width one if you wanted, which widens your choice of makes.
With a grid you can mix'n'match 1-way/2-way/intermediate modules.
You can get a brushed metal faceplate and black modules - won't be an exact match for the rest of the house, but it will easily be close enough.
I doubt you will find what you specifically want.
However, IF you can find a three-gang intermediate then that will do as they can be used as one-way, two-way or intermediate.
At least I am beginning to understand that the previous owner probably had to do what they did. Searching for "3 gang intermediate switch" is proving pretty fruitless.
Doesn't the switch that I currently have on my wall, to the left, look just like a Scolmore VP SC 025 BK or maybe a VP SS 025 BK?
Maybe if I could replace both with a VP [SC or SS] 013 BK I might be onto something... although I think 013 means a 3-gang non-intermediate switch, so I might need to look at getting 403 "1 Gang Plate Triple Aperture" and the appropriate modular gubbins to go inside it...
http://www.lightwiring.co.uk/lighting-circuit-components/light-switches/triple-gang-intermediate-light-switch/
Well why didn't you say that's what you meant.
You can also get a 6-gang in the same range.
It does seem a shame, though, not to sort this out:
2 accessories right next to each other like that never look good, particularly when 1 is crooked and they are different sizes and/or profiles.
Swapping one switch doesn't seem worth the candle for the aesthetic improvement gained.
Am I missing something? What's wrong with the click mini grid as suggested earlier? You intermediate is already a click mini grid switch.
RF
Are you saying you can positively ID the left hand switch as Scolmore?
