Internal Insulation Plan
15 May 2015
Nottinghamshire
About to insulate solid walled house room by room.
Here is what I plan to do.
Main walls:
Leave existing sound plaster on the walls
Chase plaster for ring main extension and extend 1st fix.
Vertical batten main walls with 25mm deep x 50mm top to bottom at 1200mm spacing.
In-fill with 25mm PIR board.
Overlay with 1.2x2.4m 25/12.5mm PIR/foil/plasterboard mounted to battens.
Tape & fill tapered joints (or square edge?)
Skim
Reveals etc:
Remove plaster due to depth issues.
Dot & dab whatever thickness PIR/Board I have depth for
Skim
Square edge would be easier if skimming, no?
Sound like a plan?
