Thank you.
My appreciation for your views and comments. I apologise for the delayed reply due to professional engagements and responsibilities.
Although somewhat irrelevant to my immediate question, someone asked why I believed I was 'competent' - a perfectly fair question.
Recently I upgraded my supply circuit to the workshop to a higher-current feed, from the house CU via two external junction boxes to the workshop CU. I checked continuity resistances (etc) with my own equipment, but obviously don't own regular equipment used by professional installers. Reaction times of RCD's (etc) were appropriately checked on the initial installation.
The engineer who did the original installation commented that the standard of installation was well above regular professional installation standards. For example, I dispensed with regular banjo's supplied with SWA glands and fitted Pyrana earthing nuts, and not relying on earthing SWA via the box (which the Pyrana nuts are designed to allow) I returned dedicated cabled earth bonds back to the CU earthing bus. 60A terminal blocks were used on the 40A radial feed, and cables joined by lapping through the block, ensuring two screws per junction, etc.
I also corrected a wiring error at the workshop CU, as I discovered that the neutral bus had been incorrectly used to terminate the incoming mains feed and the RCD neutral link switched around to enable the trip test button to work as a result!
It's clear from the feedback that new circuits added to the workshop CU, where there were none previously, need to be notified for legal compliance. That said, I'm now taking steps to get on a course so that I am officially recognised to self-certify my own wiring installations (I understand around 7-8 months to be fully qualified following a home-study course, starting off at level-2).
Understandably, professional installations must always be cost-effective, though I am particularly critical about my own standards of workmanship so would feel much happier doing my own work myself, and adding a valued qualification offset by the money I could save on further wiring jobs planned for next year.
Thank you in appreciation to all who replied.
FJ
